Here is it together and clean, I got about 20lbs of mud out of the radiator.
I just got dimple dies, had to build something. It helped with aiming the lights.
During construction, pre-cleaning. The skin is 11ga steel and it is welded along the edges.
This is the frame, it is 2x2x.125 square tube. It has 4 legs that insert into the frame rails on the unibody. There are several 1" holes drilled in the unibody that I will rosette weld the 2x2 to and then I will plate the frame and weld the plating flush with the front of the winch frame.
The winch is bolted on to the back of the 2x2 and the holes are covered by the skin. The fair lead is held on by two grade 8 nuts welded inside the vertical 2x2. It looks out of square in this pic pretty bad, it is off by 3/16 on the bottom horizontal tube, a friend cut it and screwed it up; I didn't catch it until I finish welded it. It is only cosmetic and the skin is square over it so it is not noticeable.
The solenoid pack for the winch is where the stock washer fluid bottle was.
The plating on driver side will incorporate bolt holes for the steering box.
The new winch sub frame will serve as the foundation for all the front tubing.
