Project Geosynchronous Orbit
Finished rebuilding everything, mounted the ecu, and started wiring.
Have to actually replace the valley pan, finish wiring, build the air cleaner, and pray I have no vacuum or fuel leaks.
Oh and also pray this all works out.
wtf why does your phone record sound like it's from 1980
How should I know.
What injectors ate you running and at what fuel pressure
40 lb/hr injectors at first 18 psi, now 12 psi. My est. HP (~450-470) tells me I need 47 lb/hr injectors if I'm using 6 of them.
We were only messing around for a short while last night. It was mostly a "let's see if we can get all of our sensor readings and MAYBE get it started/idling" kind of night.
Playing around again this coming Sunday.
thats seems really high to me especially at 18PSI
@13 PSI your 40lb/hr should be plenty
thats calculated at 85% of load as well.
