Now if I could just find another like ours where before we started into them I'd be all set!Ya, my XJ was very clean before I got mine as well. When I took my carpets out, I luckily found the same thing you did, no rust or anything.
I could never do that, just the thought of it would eat away at me.Actually, the other day when I pulled my rear carpet to install the cell was the first time I'd ever looked at it. I had been pretty much thinking "if I don't see the rust, I don't have to fix it..." So now that I know how bad it is I need to. It'll all be taken care of when I cut out the rear to move stuff around this summer.
Thanks! I spent a lot of time cleaning, grinding, priming, painting (only parts painted so far) every last part so it would be rust free and easy to work with. It is so much easier to work with clean parts than parts that keep dropping dirt in your face. Also, everything has or will be replaced. Not a single bolt or nut is being reused. I probably spent a few extra bucks doing this, but I figured it was easier while I had it apart then later down the road. Oh, and I know in the above pictures the spindle studs are the old ones, I do have the new chromoly ones, just have not pressed them in yet.Front axle is looking nice! It's making me wish I hadn't sunk so much into my 30.:dunce:
