asp
- Westport, MA
Screw 3 link Bill, go for a 6 link.
this was on the albany craigslist a little while ago. 8 link rear, anyone?
this was on the albany craigslist a little while ago. 8 link rear, anyone?[
[Pics Removed]
dont you mean front end?????? that red/ orange thing hanging down that says moroso would be an oil pan i believe!!!!this was on the albany craigslist a little while ago. 8 link rear, anyone?
that is the rear steer from the 2000/ 2002 era ( i believe ) Chevy and GMC " Luxury " trucks. the idea was good in concept but didn't last long in production. they had like 12* of left and right turning to help in tight spaces for parking etc.....I like the rack and pinion steering :roflmao:
now that i've accomplished a fair amount in my build, i really see how much extra time it takes to maintain not only a quality build such as this, but maintain record of it. i wish i had more time to make a quality build thread of my own.
SAL said:That is the sexiest thing I have ever seen...
sexy
Isn't it? :lickout:muduck18 said:SAL said:That is the sexiest thing I have ever seen...
Haha... thanks. Work shall continue tonight. Not sure if I'm gonna make the link end for the axle side of the 3rd link or if I'm gonna start the gearing. I guess it'll depend on how cold it is.Awesome...
Yours is coming out even better than I envisioned it being...
This concerns me.Also I threw the metal inserts for the RE bushings in the lathe and opened the 10mm hole up to 1/2". This will allow me to run a much large and stronger bolt.
I run all hard joints in my front suspension (including in the shocks) and LOVE it - I think the arm geometry is FAR more important than the bushings in the NVH (noise vibration and harshness) considerations...
I'd encourage you to re-think using a bushing in a 3 link with panhard style suspension.
Thanks!Cryke RCMan! Amazing, good work. Dont suppose you'd like to share the templates for the unistiffeners do you? When stiffening up the rails I'm not clear what you've done, the inside and bottom or outside and bottom or both? Looks great, keep up the good work.
I've got to stop readingbefore I go to bed.
I laid awake trying to think of something else to do.
You do make good points about the rubber bushing and after looking at it again this morning, I think you are both right. The rubber would just be too soft of a compound with all that force the one upper link sees. As far as the bolt size goes, 1/2" is the largest that I'd feel comfortable with as after the next down with a 9/16" bolt it would leave a 0.071" wall thickness.... no good at all.
I do have some 'medium sized' poly bushings that are 1-7/8" OD, 2-5/8" mounting, and 9/16" bore for the bolt. Granted I know that that is still not a hard joint, but the poly is much firmer than the rubber (at least in "on the bench feel"). I'd change the axle end mount around to the more "conventional" style so that the poly bushing would be on the end of the link making it much easier to swap it out for a flex joint at a later date if need be. This would give me one end with a flex joint and one end with the poly. I could mount the link either way so that the flex joint could be on the axle side.
So... what do you guys think about that?
