kmanxj5050
- Reed City Michigan
Little history behind the name, this is my fourth xj/mj.
My first was a 2001 i bought in 2006 when i was 17. Traded that off for a dodge ram in spring of 2010. It was bone stock, i put a 3" RC lift in it, then 4.5 rustys then made that 6.5".
here it is:
Then i sold the dodge i had to pay bills to but a house then bought this xj in early 2011.
Then i traded that for this mj like a month or two ago.
Which i still have but i put the rod through the block last weekend. It had some rod knock when i got it but the suspension and axles are killer!! Front HP 30 with 4:88 gears, lock right locker, superior alloy shafts, teraflex high steer knuckle, and highsteer heim joint steering. With RK long arms.
The rear is a 8.8 with 4:88's and limited slip with disc's. And it has 35" BFG Krawlers.
This thing also has some wiring gremlins and crap so.............
I bought this saturday and its alll going under it real soon.
Its a 96 with 149k miles, runs like a top, and EVERYTHING works as it should.
now all i have to do is find some leaves.
But i was also thinking about just putting the 8.8 in it before i do the front and lift, and take it to the drag strip on the small tires!!!!! haha should be quick with that deep of gear and little tire!!!! We'll see though. :looser:
here it is:
