it mounts to the stock holes, but with 6 big grade 8 bolts and two triangular cut pieces of plate, with a 2" strip of plate welded to the edges(of the plates). there are 2 weld through D shackle clevis mounts tied into the plates, and also welded to the tubing, which is all 1.75" except the 2 pieces supporting the hoop. what measurement do you need? height of the hoop? width? a friend i used to work for built mine. if you want, i could give you his phone #. he's in gallatin, tn. i'll try to get some better pics of the mounts and important weld places later today or tomorrow.
