kndrewa
- Vancouver British Columbia
I was reading ehall's "beater!" thread, and it reminded me of a loose end I've been meaning to tie up.
He picked up a 97+ axle for his pre-97 XJ - but can't use the parking brake because of the cable differences.
I didn't want to clutter his thread with my inquiry, so here it is.
I put an 87xj d44 into my 97xj.
So I have the same problem as ehall, reversed.
My old d35 went to the yard along with its parking brake cables.
* On 97+ xjs the cables from each drum are both routed along one side of the frame rail.
* On pre-97 xjs the cables are equal length and run under the body above the rear drive shaft.
I'd like to use the equal length cables from the d44.
Mostly because I don't have access to my old cables and I'm not sure the d35 e-brake fittings would fit in the d44 drums.
Seems like I need to do two things to make this work with my 97xj and 87 cables:
1.) fab up some guide brackets on either side of the driveline tunnel
2.) attach the pre-97 equal length cables to the 97+ brake handle/cable assembly
An advice on this?
Maybe it actually is simpler to go find some d35 cables at the salvage yard and fit them into my d44 drums?
Only thing keeping me from swapping it in is that it's from a 99 so the parking brake cables are wrong.
An advice on this?
