I've found the posts that have the 3 reference values listed (90,220,260).
My question is does anybody have a more detailed chart?
Something to the 1deg would be great but even to the 5deg would help.
Yes, resistance at specific temps. I've been running hot but I'm also not entirely trusting of the factory dash gauge. I'd like to compare my readings directly at the sensor with what I'm seeing on the gauge.
The sensor/gauge combination is not inherently accurate enough to lend much credibility to degree by degree resistance figures. You need to get an infra-red (IR) thermometer and measure temps at the thermostat housing and near the sensor location at the rear of the head to see what is really going on.
I went through this with my '93 where the gauge was showing mild overheating while the IR thermometer was indicating normal temps. I finally replaced the after market sensor with an OEM unit which cured the discrepancy.
BTW, you will get answers here but just for future reference, this is really an OEM question.
