SoCal Off-Road
- Rancho Cucamonga, CA
not to sound stupid here, but how many tires could be aired up with this setup?
(edit: I understand that will vary greatly depending on size and psi, but some idea would be appreciated)
When is the deadline for this? And what would be the best way to pay?
Jp said once it was advertised as 12 tires but they could have gotten more out of the system. That was for a 10lb bottle. I am thinking about getting a 20lb bottle that way if I need to, I can run some air tools for a bit and know I still have enough in the system for tires if needed.
If you are going to use a compressed gas instead of conpressed air, why not use Nitrogen? Lighter than CO2 and as an added benefit, you can expect your mileage to get better. Up to 10% better...
Here is a Link http://www.getnitrogen.org/n2study/video/leno.html for a video by Leno. The Military uses it as does NASCAR, F1 and others.
Check it out as an alternative to CO2.
