EndlessMtnFab
- Paxtonia, PA
Ok everyone .... Have a question in which the answer would be more of an opinion than an outright fact.
I have replaced the steering box on my 97 XJ with that of a 79 J20 (already took care of the hose fittings). I did this because of my desire to run a 4 bolt box with a larger piston. At the same time, I wanted to keep a box that was very similar in characteristics to the factory gear box.
So far, so good ?
My XJ will be running 33s (285/75/16 flavor) so the extra "oomph" was a good deal for the rocks. The frame has been braced forwards, backwards, upside down, and maybe even inside out.
Ok .... the question is which of the 2 power steering pumps would be a better choice ?
1) Reman OE power steering pump for 97 XJ (factory application)
2) Reman OE power sttering pump for 01+ WJ
My understanding is that the WJ pump can be fitted with mild mods ( I just happened to stumble across that info while looking for the J20 box specs ). From what I read, the WJ box provides a little more boost. My concern is that it would start to feel "over-boosted" kind of how the late 80s early 90s Cherokees felt.
Steering linkage wise ... I am running an OTK / Inverted T arrangement. The draglink angles are definitely acceptable right now and but will still be further improved later on (relocating the track bar AGAIN). I do not anticipate quite the roll issues based on the steering knuckles I am using .... but I'm not going to say it would be completely eliminated until I drive it. :gag:
Right now ... my gut feeling tells me to just get a reman XJ pump. If so .... I would think the J20 box alone would be sufficient for 33s for my intended usage. Am I correct in this line of thinking?
There is a 20 dollar difference between the 2 pumps -- so price is not really a factor ($70 vs $90).
Can anyone share some input? All responses are appreciated. Even the http://www.naxja.org/forum/search.php ones. :laugh: If you need some more specific information, please ask me. I will be keeping my eyes on this thread.
One of these days I'll get my build thread here too. Should be interesting to see the
reaction. :doh:
THANKS !!!
Joe
So far, so good ?
THANKS !!!
Joe
