dagr8tim
- Columbus, Oh
First off, I've found several threads that skirt what appears to be my issue, but none that directly address it. This is on my 97 4.0/Auto.
I've noticed the PS fluid get low afew times and figured I had a small leak. Sometimes there are spots on the pavement, sometimes there are not. At the time I figured I'd monitor it and continue to add PS fluid.
About a month ago (one of the first really hot days), I started the jeep and let it idle for about 15 minutes while I was waiting on family. When I started to back out, I got a small puff of thin white smoke. I assumed it was just excess fluid burning off of hot parts. I had to turn the wheel to lock or near lock to back out of the parking spot when I got the smoke.
Last week I went to dinner and had to backup and pull forward to squeeze into a parking space. Once again the wheel was at lock or near lock, and I got some smoke.
Today, I had to really squeeze to get into a parking spot. Turning the wheel to lock several times to get in. I got more smoke.
I popped the hood and noticed the following. The shaft from the steering wheel had a spot of fluid on it, and there appears to be fluid sitting on a lip on the inside subframe. One thing to note, is that I've never noticed fluid on the steering shaft before.
The following picture shows the wet spot on the steering shaft, and you can see wet clean PS fluid sitting on the lip.
I'm assuming it's either a line or the steering box. And due to the small amount of fluid I appear to be losing and that the problem seems to happen at or near wheel lock. I hope the low pressure line.
From reading other threads, I know the low pressure line is just tranny line (which is why I hope it's the low pressure line). I also know that flair nut wrenches are a must for the job. Lastly, I have a parts 98 XJ that doesn't appear to be leaking as donor parts.
Any help or suggestions would be great before I tear into this blind. I also have not gotten anyone to turn the wheel while I look for a spray of fluid. Once the Jeep cools down, I'm going to remove the air box, wipe everything down, and try that.
