Carpcommando
- Grass Valley, CA
1996 with Champion truck plugs and wires...175K miles
I have noticed for quite some time (several years)that my engine is some what doggy until it hits around 3000 RPM then it really cranks well with substantial power well to 4500 rpm. Kinda like when a turbocharger kicks in after a bit of turbo lag...
Also, if I floor the accelerator from a stop, the engine bogs down and runs stronger if I back off slightly to about 85-90% of full on throttle.
I changed plugs, wires, rotor, and cap with no difference in performance.
No difference between stock air cleaner and K&N replacement.
CAT was replaced 30K miles back did not seem to make any difference in performance.
Muffler is a hi flo replacement
Replace intermitant TPS...no difference on the performance.
Could it be time for injectors? I use injector cleaner every 3-4 tanks of gas.
How about the distributer? I replaced the OEM with a NAPA rebuilt one several years ago...
Any suggestions appreciated.
Mike
Mike
