power fuse locations: Bendix ABS?
Hypoid
Golden, CO
Hey all, I'm at a bud's house, this is my closest resource, I tried searching.
Where are the power fuses for the Bendix ABS actuaters?
We've taken a few voltage readings, not getting anything at the relay coil; contacters OK, nothing at the coil.
I found 2, 2 amp fuses in the panel. Now I'm looking for the pump power fuses.
TIA, Mike
At the accumulator? Yep, have voltage there. Checked across the pressure switch for continuity, it read open. Jumped out switch, nothing. Checked across the relay coil for continuity, that looks OK as well.
With all these spot checks, I'm not ruling out more than one problem here. We'll just have to keep plugging to find it.
On the '91 they are in the main power distribution box under the hood. It's the black box near the hood prop rod and battery. There is one fuse for the pump and one for the ABS computer system. Don't know if this holds true for the renix equipped XJ's though.
Bendix survivor...
Bones :skull1:
Mine used to be the crap Bendix ABS, now it's a '99 XJ/ZJ/Explorer 4wheel disk.
Thanks fellas! We went ot the bone-yard and got lucky, found a dual diaphram booster on a '96. No need to trouble shoot the ol Bendix 9, we couldn't find extra parts for it anyway.
