Power door lock wiring.... FSM gods????
90Pioneer
USA
OK I'm having an intermittant short in my driver side power door lock in my '96 Cherokee Country.
I've pulled the door panel off and removed the wiring harness (PINA). But what I need to know are which wires affect the driver side door lock?
If someone with a FSM could help me out that would be great.
Thanks!
Pink/Black and Black/White are the colors at ALL of the actual motors.
I don't know if this helps, but the major hot wires (from the fuse block) for the whole circuit are:
White/Black--fuse 17, 7.5A switched hot
Lt. Green--fuse 13, 20A always hot
Pink--fuse 9, 10A always hot
EDIT: At the motors, Black/White are positive, and at the relays, Pink/Violet control unlock and Orange/Violet control lock.
After removing the tape and looking at it a bit more closely, it became clear... the pink/violet wire was snipped in half. The only thing holding it together was a small bit of insulation. Spliced it back together and I am golden.
