50' when wet? man i used to do that out of stop lights by accident if it was wet if i went a little to hard on it. my jeep when it was on the road would roast through 1st gear and keep spinning in 2nd all the way down the road and just stay there, the rpm's would'nt go up or nothing it would just keep spinning at about 50mph until it bogged slightly then caught traction at about 50-55mph. this was with 245/60R15 Radial TA's, the front end lowered about 2.5"s, alot of weight saving as in no spare tire or jack, no back seat or rear seat belts, no carpet or insulation, removed interior moldings and numerious other things along with a toyed around with motor. When it was bone dry i could lay into it on any type of pavement, up hill or downhill and break 1st gear loose to the point where i would have to let off the gas to let the tires get traction and stop the motor from jumping right up to redline. God damned i miss driving that thing.
Eric
