- Houston, Tx
I just finished insalling a 4x4 Posi-Lok system on my Jeep.
I've got a 94 Cherokee, which has an 89 Disco front axle in it. I bough this axle as it was cheaper than re-gearing to 4.10s. I bought the posi lok setup as 2-low appealed to me.
Anyways, I've found a few issues with it.
1. I bought the one for lifted Jeeps, it states its for 3" lifts, I'm at about 4.5", and the cabe is way too long
2. I first installed it with the axle disengaged. When I went to test it, I found that it would not engage. I re-installed it with the axle engaged, and found that it will not disengage.
I thought no big deal, at least my 4wd works. Then I took it for a test drive. while the collar at the CAD was engaged when I put it on, it seems like it is not now. I put it in 4wd and just got vibrations and grinding noises, obviously not right.
Did anyone else have issues when installing one of these? What should I do to correct this?
Thanks in advance.
Thanks in advance.
