poly bushing?
so it seems i f*cked up somewhere. i measured the swaybar right by the bushing cause i figure that would be the best place. it measured 1.035. i used 2 different converters and one said 27 and the other said 26. both of those sites show 25. and 28. so i dont know. i'm going to have to see if i can get a mm micrometer.
rsalemi said:
measure it in inches - I beleive Energy Suspension has poly bushings in inches.
Nope, their bushings are in mm. You'll need to accurately measure the outer diameter of the swaybar with a caliper to ensure that you order the correct size bushings.
I don't want to put you off using poly bushings, but they do have a tendency to squeak if not well lubricated with the special teflon grease that comes with the packs (at least the Daystar packs). My control arms squeak like an old hooker's bed when the weather's dry, and I've not done the uppers yet.
