Talyn
- Radford, Communistwealth of Virginia
5.0TB will be too large. Throttle will be difficult to control and very touchy.
wolfpackjeeper said:yea, I think Dino has the mod for using a 5.0 TB on our intake on his site
I pulled the trigger! I ordered my ATK 4.7 this morning. Total was $2,750 and it will be here in 3 days. 2 year unlimited mileage warranty and it covers parts AND labor!
Where are you seeing $2750 and 2 year unlimited warranty? Also, Whats the price of shipping?
Just in case my engine goes boom!
There are several options for tunning. The Unichip is good, but you need to either find a shop that can tune it (you can't yourself) or go with a shop familiar with the stroker to send you one with a tune on it already, like Hesco. The Unichip is a piggy back and can adjust a host of other parameters besides AFR and timing. An SCT tuner is also another good option and can do what the Unichip can do. Like the unichip you have to find a shop that can program one or find a dealer that can send one out with a tune. The SCT is a plug in programmer.. plug it in to your OBD port and flash the PCM. Split Second PSC or Apexi can be used. They are both AFR piggy back tuners which you can change yourself. Expect to spend about $400 for the tuner and I high recommend a data logging wideband gauge.My concern is when things turn to computer/electrical. If this will require tuning, then what needs to be done? How? What tools? How easy can it be done? And can I just take it to someone who can do this?
It depends on how he is tunning the GM PCM. I know that some GM PCMs are open, meaning they can easily be changed with just software. If that is what he is doing it wont' work on a Jeep JTEC PCM. If he is using an SCT or Unichip type or other piggy back he shouldn't have problem tuning a Jeep engine.By the way, if someone is familiar with building and tuning GM engines, is it easy for him to tune jeep stokers ? Or does it require different skills, tools … etc.?
Red97XJ, any updates on you purchase?
Out of curiosity did they tell you exactly what happened?
I can understand the warranty if it was something your fault or no ones fault. But it was their fault! Why should you have to spend another dime? That's crappy.
Notice any better mileage?
