serialphreak
- Estevan Sk Canada
M4Madness said:First, I've read the tacked FAQ and read through 34 pages of topics that came up when I searched for "gear".
I have a 1996 Cherokee Sport. It has a 4.0L engine, an automatic OD transmission, and 3.55 gears. I'm wanting to lift it and install 31's. It is my daily driver, with most driving at highway speed. From my calculations, to get back to the stock gear ratio after adding the bigger tires, I'll need 4.11's.
Some say that I'll be happy with 4.11's, while others say to definitely go with 4.56's. I'm leaning towards the 4.56's, but want to be sure that I won't be disappointed -- some say that this is too low-geared for 31's.
Hopefully this can put the argument to rest, and future newbies will benefit from the input. Thanks.
mud4x4lover said:i wouldnt even worry about wasteing your money on gears for 31" tires if you have 4.o motor you will not realy even notice it at all i have ran 3:55's for a long time with 33" tires i would spend money on a gear set for your transfercase.
woody said:I am not clear if you have a D35 rear or a 8.25".
cdhowell said:Stop and think that the charts are based on 1:1 ratio's in a manuel tranny. and the 31's will be a little wider increasing rolling resistance. The taller stance will increase wind resistance. Milage will drop slightly even if you regear. I say do a budget boost and get a set of trail tires for your hunting trips. a used set will cost half of what regearing will.
woody said:The dood lives in Indiana and what, exactly would a gearset for the transfer case supposed to do for him???
For short money in similar use, I'd pick up a front 30 with 4.10 out of a 4cyl 92+ XJ, use whichever brakes/ hubs/steering are in better shape on the donor, and keep the other junk for spares.
I am not clear if you have a D35 rear or a 8.25" (or if they put 4.10s in the 8.25s) but either find a 4.10 swapper or regear the back. You would not need a new carrier for either of those axles... just ring & pinion gears, install kit and a gallon of oil.
Me personally, I've done 4.56 & 31" (4.0 AW4) and loved it. No probs at 75-80 on I-40. I have 4.56 waiting to go in my current ride... but at one point had 4.10s and decided not for me (hilly backroads mostly) Also consider that those 'XX" tires' are probably a lesser working radius, so "do the math" with that in mind.
regearing (opposed to swapping in ready-set axles) is kinda expensive... even if doing it at home. Not something to do often IMHO.
You can run any gear ratio with 31s!! They're 31s, practically stock! Who cares. Maybe not 3.07s, but 3.54s, 3.73s are FINE FINE FINE!
4.56s w/ 31s, are you kidding me! What a waste of time and money!
Leave your gearing stock with 31s, literally 2.5 inches taller than stock tires!!
People think too much about these Jeep ideal perfection figures.
235s - 30s - 31s - 32s - 33s - 34s - 35s
stock stk stk 4.10 4.10 4.10 4.56
4.56
I guess no one noticed this thread is/was 2 years old
