Professor Bobo
- Casco Township, Michigan
I replaced the u-joints on the front axle and now diff fluid is leaking out the drivers side.(the short side). I know that it's probably the seal. My question is: How do you access the seal? Is it thru the axle tube or in the pumkin itself. The axle is a D30 non-vac. disconnect in a '93 XJ. Any help would be appreciated.
Thanks!
Thanks!
