Dumb question......Have you looked at your steering geometry and determined that you need a drop arm? My appology if you know what you are doing, but many people think that just because they lifted their rig that they need a drop arm. The reason to change the arm is to keep the drag link and the track bar parallel. If they are not parallel, you get what is called bump steer. If you haven't modified the location of your track bar mounts, most likely you don't particularly need a drop arm. You can actually cause problems instead of solving them. Once again I appologize if you understand the issues and really need one, but I see too many people spending money on something that may actually make things worse.
