Pinion Seals, D44
ChEwBaCcA
Chicago
Where am I going wrong here? Had a seal replaced along w/ new gears and full rebuild last year. Seal was Ok for a while and then started to leak"about 2 months" after the axle was rebuilt.
Went to replace the seal last weekend.."a year later" .its leaking worse than w/ the 1 year old seal!....also replaced my front d30 seal , same seal same manner and its fine.....
any tips:? its leaking from the seal not the metal to metal edge around the housing.
Im about ready to put a zip tie on the seal to tighten it up...seems to me the seal doesnt make a very tight fit on my yoke.
Its not overfilled....the pinion is tilted up some to keep it inline w/ my CV shaft
It was a Timken seal , so its not a $2 cheapo special
The spring goes on the inside towards the bearing no?
Regards
Chewy
If it's not related to the change of angle, you might have a worn shaft. If so you might want to look into these sleeves that are made specifically for worn shafts......might still help you out even if the shaft is not worn.
Micro Sleeve, Arlington, TX 800-475-3383, Specializes in making wear sleeves for worn sealed shafts.
http://www.microsleeve.com/
Speedi-Sleeve is another alternative and can be found at
http://www.chicago-rawhide.com/auto/speedi/speedi.htm
Good luck,
Jay in MA
But this is just a pinion yoke issue, seems to be easier to buy a new yoke? Or could this be a bearing/angle issue? The yoke while tight w/ nut didnt seem to move...or maybe its moving around under load?
Regards
Chewy
