bryanv
- West Chester, PA
i am putting a d44 front and d60 rear in an 88 cherokee i do not have the car to do a mach up on. was wondering if you guys who are running around 7 inch of lift have your pinion angles set to. i dont want to have to use any shims on the rear, so i am going to weld the leave spring purchases according to the pinion angle i need. the front i will have adj uppers so a ball park range of plus or minus 1 degree would be fine. Any help would be appreceiated.
thanks
bryan verdeur
thanks
bryan verdeur
