I've been researching info on rock rails. It seems that nearly everyone builds these to utilize the pinch seem to do most of the dirty work. It also appears that the connections to the frame rails are simply intended to help avoid having the pinch seem get jerked around.
However, I have found one exception to this pinch seem rule. Kevin's OffRoad armour claims that his latest generation of sliderz do not need to use the pinch seem.
From his website: It's an old picture, so please disregard the pinch seam mount...it's no longer needed due to an update in manufacturing and an upgrade in strength.
http://www.kevinsjeepparts.com/xj/xj4.html
I'm interested in knowing where the brunt of the force is now being taken. Distributed along the rocker panel perhaps? I also assume that a cut in the pinch seem would be required as it would just get mashed in anyway.
I'm hoping to fab up my own set for my own rig this winter and hence I am collecting ideas. The Tech Article on Mesa4x4 was interesting in that the desgin was much simpler in that it used 2x6 box tube that required fewer welds and such.
Also, although I'm rambling at this point, I was also intersted in a comment that was made about using the internals of large rockrails (e.g. 2x6 box tube) as tanks for on board air. I'll be looking into that possibility as well since I'm hoping to have OBA of some sort down the road.
Any comments would be appreciated.
