montanaman
- Western Montana
Ok ... just finished making my oil catch can with stuff I found from Home Depot. Many thanks to Dr. Dyno for posting the instructions on his website. I used epoxy putty, which is easier to form into shapes with your fingers than JB Weld. Total cost for everything was about 5 bucks.
Here is a basic shot of it, showing the connections and the visual gauge:
Overhead view:
Detail of valve cover connection, made from 1/2" copper pipe. Notice that the part outside the can is fatter than the part inside. That's because I "sweated" (brazed with plumbing solder) a junction piece onto the end of the pipe. That gives it those nice lips for holding on the hose to the valve cover (please ignore the sloppy soldering job. I'm cleaning that up with a file.):
Upside down shot showing drain hole on bottom:
Detail of the drain nut epoxied onto the bottom:
I still haven't decided what to put inside. It will either be sponge or the "scrub brite" steel scouring pads that Dr. Dyno used. The last step will be to put on a lid and seal it up with more epoxy.
Then we'll have to see if this thing catches any oil!! My 4.0 motor has about 3 thousand miles on it, and it seems like the rings have sealed up very well. So I probably won't have a lot of blowby. But it's still good to have this there, and it's a hell of a lot of fun to build!!
Overhead view:
