MuddinJeeper
- Maple Ridge, BC
duct tape:dunno::laugh:
Mambeu said:Hot floors are a good thing. I cook lunch on my transmission tunnel all the time when wheeling. Seriously.
i saw in issue of JP mag where they did something like that to a tub of a wrangler. they layed a coat or two of herc down. then covered that with some heat/sound deadener matting. and followed up with more herc. they didn't say anything about having to seal up the matting though. and they left it at that and didn't reinstall the carpeting. they even measured the sound and heat before and after the mod and it made a pretty big difference IIRCNCCherokee said:Do you think it would work if you ripped it all out and herc'd it, then put some sort of heat/sound deadener, then tried to herc it again, after sealing the edges of the deadener with silcone or something similar that is suited to that job. Then maybe you could cut your carpet into pieces so they are easy to remove. That way you could be insulated from heat and sound, and you wouldnt see the tacky foil backing all the time. You could take it a step further and get some of that velcro that you just stick on, and put it on a couple of spots on the carpet and floor so that the carpet doesnt move around.
It wasn't a Wrangler; it was an M715. It was last month's issue, I think.FitchVA said:i saw in issue of JP mag where they did something like that to a tub of a wrangler. they layed a coat or two of herc down. then covered that with some heat/sound deadener matting. and followed up with more herc. they didn't say anything about having to seal up the matting though. and they left it at that and didn't reinstall the carpeting. they even measured the sound and heat before and after the mod and it made a pretty big difference IIRC
Depends on how thorough you want to do it and how picky you are about going over wires.1985xjlaredo said:Are there any wires that run across the floor or in the door sills that need to be pulled up also? And how much door panneling needs to be pulled?
