Password info for Members Only areas (roster, tech articles, chat, Den)
Status
Not open for further replies.
WebTeam
On Thin Ice
On Thin Ice
Password info for Members Only areas (roster, tech articles, chat)
Tech articles
and Chat (linked in forum Navbar, using the default theme) and members roster.
Please use the following
username: naxja_member
password: xjarchives7a
The Den Password: Contained in post
Basic guidelines
No illegal content.
Probably not Work Safe.
Probably not Children appropriate.
The BOD reserves the right to change, modify rules at any time.
Common Sense :)
Password: iwillreadthedenrules
Re: Logon info into for members only area and Chat Rules
UPDATE Username and password are *YOUR* username and password, notthing else.
[size=-1]Administrator, 9/18/2008[/size]
Chat Rules:
RULES AND CONDITIONS FOR USE OF THE NAXJA CHAT AREAS
NAXJA users agree to the following rules while using the NAXJA chat rooms:
Do not harass, badger, heckle, disrespect, annoy, taunt, aggravate, insult, swear at or be rude to any chatter. They have feelings too. And they can mute and/or remove you from the chat room if necessary.
a) You SHALL use your NAXJA Forum Username for the duration of your chat session. If you impersonate another Member, User, or any other person/Name, you will be removed from the Chat.
b) You shall not use any Bots or otherwise use the chat for ANY purpose other than to "chat".
c) Making statements that are false or grossly offensive including blatant expressions of bigotry, racism, hatred, or profanity.
d) Indulging in abusive, defamatory or harassing behavior or insults or personal attacks or threats of harm to anyone or promoting physical harm or injury against any group or individual.
e) Promoting or providing instructional information about illegal activities. You also may not indulge in activities that infringe upon anyone else's copyrights). Specifically, you cannot advocate illegal conduct or participate in illegal or fraudulent schemes. You can't use our chat rooms to distribute unauthorized copies of copyrighted material, including photos, artwork, text, recordings, designs or computer programs.
f) Engaging in sexually-explicit chat or nicknames that would generally be considered offensive in a public place.You shall use your NAXJA Forums Username for the duration of your Chat sessions.
g) Impersonation of or false representation of yourself as a NAXJA moderator ircOp or BOD Officer.
h) Harassing or any other form of contempt, discourtesy,impoliteness or debate with any OP or forum Moderator will result in your removal from the Chat rooms.
i) Posting or transmitting of unauthorized or unsolicited advertising, promotional materials, or any other forms of solicitation to other users, in these chat rooms, except in those areas that maybe designated for such a purpose, is strictly prohibited.
j) Discussions should concentrate on topics relevant to each room (i.e. Club Chat in #main, etc.), except for the Channels created for that purpose. Any unauthorized channels may be removed at any time.
k) Any abuse of irc services or server will result in a permanent ban.
ANY VIOLATION OF THE ABOVE RULES AND CONDITIONS WILL RESULT IN LOSS OF CHAT ROOM ACCESS PRIVILEGES FOR THE OFFENDER.NO COMPLAINTS, BREAK THE VERY SIMPLE RULES, YOU LOSE CHAT PRIVELDGES.
*IF* you're having problems with the direct link out of the forums for NAXJA Chat, try downloading the attachment to this post.
It's a .zip file. Unzip the contents into a folder, and run client.exe.
Everybody should thank cal for digging this one up.
  • naxjachat.zip
Something else..... for other problems with the browser based chat, delete everything in this folder:
C:\Documents and Settings\username\Application Data\Macromedia\Flash Player - or -
Obviously, you'll need to change username to whatever you're logged into your Windoze system as. If you've got your documents folders somewhere else, you'll need to go there.
Yes, this is Windows specific.
Re: Password info for Chat
Oops. I should have noticed this earlier...... Chat login is *YOUR* username and password.
From GSequoia, for the Mac users:
The easiest way to flush Macromedia Flash Player's cache in OS X is to do the following.
Go to Finder by clicking the finder icon (left most icon, looks like a face) on your dock.
In the menu bar at the top of the screen hit Go, then Home.
Double click on Library.
Double click on Preferences.
Double click on Macromedia (you will have a lot of scrolling to do to get here).
Drag the Flash Player folder to the trash can.
Close that window, you should now be able to use Flash Chat.
Status
