Parts lots of XJ parts
You wouldn't happen to have the crank position sensor and coresponding harness pigtail from a 95 4.0 Auto would you? When I bought my jeep the sensor was connected with household wire nuts, and the mechanic I took the car too lost track of which wires were which on the sensor side leaving me with a bad sensor and this...
Unfortunately the harness is being sold with the motor. I do have a few CPS sensors that could have the wiring pulled down to verify terminal connections.
Splicing them shouldn't drop the OHM's so you should still get the proper OHM's from the CPS to the PCM.
Dave
On the sensor side all of my wires were black, and I was told that if they were hooked up in reverse I could fry the sensor. I probably will try splicing it in until I can find that connector for a more permanent solution. Thanks for the quick response.
Dave. Crankshaft Position Sensor for a 92 HO. when swapping motors i snapped mine clear off the bell housing. you got my numba let me know.
I have a HO head, I can't remember the casting number but it's one of the most desirable. 0630 rings a bell. I had it for my 4.7 stroker and never got to finish it. I'll Have to see what they go for.
Forgot to mention. but its specific for the 91-92. all other years have a different connector at the harness.
adding parts daily..
Low pinion D30 housing $50
D30 CV axle shafts $30.00 ea
ZJ D30 knuckles $30 ea.
D30 Carrier $30
D30 Unit bearings $25 ea.
ZJ Tie rod and drag link $80.00
HPD30 housings (vac Disconnect style) Will include block off plate.. $50.00 ea.
HPD30 carrier 3.55 and down $40.00
HPD30 Shafts Vac disco (260 U-joint) $20.00 ea. long and short side.
XJ D35 complete axle w 3.55 gears $100.00
XJ HPD30 complete axle w 3.55 gears Vac Disco. $100.00
Misc Axle parts, please email call or Txt for your requests.
email, call or txt
Dave
480-600-9174
Adding more parts daily!!!
HPD30 non disco complete axle $200 Rotors in.
91 AW4 126K $250.00
Np242 21 spline $100.00
D35 Lincoln locked $100.00
85-92 Column with keys. $50.00
Shifter and linkage for T/C $40.00
Gauge cluster $40.00
Dave
480-600-9174
Updated list 10/12
Txt and calls ok. 480-600-9174
91 4.0L complete engine pan to intake compression test results 150-160 across all 6 cylinders $650.00
XJ rear stock leaf packs $20.00 ea.
Renix (pcm) computer $40.00 ea
2 XJ renix engine harnesses $40.00 ea.
Misc harness plugs and connectors (call, email or txt for specifics)
XJ fan blower motor $10.00
XJ front seat belts w retracters $10.00ea (male side only.)
XJ Pitman arm $30.00 ea.
XJ steering sector shafts $20.00
Misc Steering column parts. $10
XJ (1991) tilt steering column w keys $40.00
XJ Steel battery tray $20
Dash Bazel black/silver Good Jeep XJ,MJ 2 $15.00
Stock Air box Good Jeep XJ,MJ 1 $10.00
Cone filter setup Good Jeep XJ,MJ 2 $10.00
Front 4dr Interior door panels Gray Good Jeep XJ,MJ 1 $20.00
Rear 4dr interior door panels Gray Good Jeep XJ,MJ 1 $20.00
Front and rear floor mats gray Gray Good Jeep XJ,MJ 1 $10.00
Map Sensor Good Jeep XJ,MJ 1 $10.00
A/C control panel Good Jeep XJ,MJ 1 $10.00
Rear view Mirror Good Jeep XJ,MJ 1 $10.00
Defroster switch panel Good Jeep XJ,MJ 1 $10.00
Cig lighter panel Good jeep XJ,MJ 1 $10.00
Rear wiper switch panel Good Jeep XJ,MJ 1 $10.00
Header panel wiring harness Jeep XJ,MJ 1 $15.00
229 Transfer case $60 ea
XJ D44 Housing (bent housing) $40
D44 Dif covers stock x3 $20 ea
Np231 Transfer case parts (gobs of parts) just email me with inquiry
Roller fair lead $25
1 inch Steel coil spacers $25
Hood w/ Vents -Green Good $80 Jeep XJ,MJ
Fenders Cut fenders with minimal damage Good $20 Jeep XJ,MJ
Header panel Header panel w lights damaged $20 Jeep XJ,MJ
Transmission Aw4 Transmission Good $250 Jeep XJ,MJ
Carpet Front and carpet kit - Gray needs cleaning $20 Jeep XJ
Carpet Rear cargo area Black Needs cleaning $20.00 Jeep XJ
Seat Rear Seat - XJ - Gray Good $20 Jeep XJ
Door handles Black exterior Door handles (4) Good $5 ea Jeep XJ,MJ
Door panels Gray - Door panels - Front 4dr (2) Good $20 ea Jeep XJ,MJ
Door panels Gray - Door panels - rear 4dr (2) Good $20 ea Jeep XJ
Mirror Pass. Mirror - black Good $10 Jeep XJ,MJ
Wiper motor Wiper motor Good (85-90) $20 Jeep XJ,MJ
Cowl Wiper motor cover - Green Good $10 Jeep XJ,MJ
Cowl Wiper motor cover - White Good $10 Jeep XJ,MJ
Cowl wiper motor cover - Purple Good $10 Jeep XJ,MJ
Handles Interior oh-shit handles - gray (4) Good $5 ea Jeep XJ,MJ
1/4 Glass Rear 4dr 1/4 glass 4dr (2) Good $20 ea Jeep XJ
1/4 Glass Rear door, 1/4 glass - 4dr (2) Good $20 ea Jeep XJ
Tail light 84-96 XJ tail light Good $20 ea Jeep XJ
Transmission Cross member AW4 Good $15 Jeep XJ,MJ
Shifter AW4 shifter Good $30 Jeep XJ
T/C linkage 242/231 T/C linkage Good $15 Jeep XJ,MJ
T/C shifter 242/231 T/C shifter Good $20 Jeep XJ,MJ
T/C linkage body mount Body mount T/C linkage Good $10 Jeep XJ,MJ
Brake Booster Good $20 Jeep XJ,MJ
Master cylinder Brake Master cylinder Good $20 Jeep XJ,Mj
Pedal assembly Brake pedal assembly Good $20 Jeep XJ,MJ
E-brake assembly E-brake assembly Good $10 Jeep XJ
Dash Maroon XJ,MJ complete unit minus gauge cluster $25.00
Rear seat XJ maroon plaid $20.00
Center console Maroon, XJ.MJ $15.00
Rear Seat XJ 4dr gray XJ $30.00
Carpet kit,2dr XJ ( Red ) Needs cleaning $25.00
Door panels 4dr Gray XJ Satisfactory $40.00 complete set.
Dash Gray XJ,MJ $40.00 complete unit. -no cluster
power Sunroof for XJ,MJ will include roof section to blend into another roof. $75.00 (includes seals and latch)
Rear XJ Hatch x2 w/or w/o glass Hatch $40.00 glass $20.00
2dr XJ door glass $20.00 per piece
4dr XJ side, 1/4 door and door glass $20 per piece
85-86 2.8L or 2.5L equipped XJ,MJ front clip $200.00 (fenders, hood, grill, and header panel) note: fenders were poorly cut by previous owner
2x 2.8L v6 XJ,MJ known running motors. $300.00 ea.
2x 2wd MJ rear drive shaft D35 equipped w slip yoke $30.00 ea
2.8L engine components email requests please.
Misc trim, interior and exterior please email requests.
Bulbs Misc light bulbs Good $1.00 Jeep XJ
HO knock sensor knock sensor 4.0L HO Good $2.00 Jeep XJ
Buzzer mod. Buzzer module Satisfactory $2.00 Jeep XJ
Timing chain cover gasket New $5.00 Jeep 4.0L
Dip stick 4.0L dip stick Satisfactory $5.00 Jeep 4.0L
Head bolts HO motor Satisfactory $5.00 Jeep 4.0L
Digital clock Interior Digital clock Satisfactory $5.00 Jeep XJ
Wiper switch Interior rear wiper switch Satisfactory $5.00 Jeep XJ
Hood light Under hood light Satisfactory $5.00 Jeep XJ
Glove box light Glove box light/clasp Satisfactory $5.00 Jeep XJ
Trans/Wiper switch comfort and wiper switch Satisfactory $5.00 Jeep XJ
Cig lighter Cig lighter and internal mount Satisfactory $5.00 Jeep XJ
Fill tube Fuel tank fill tube Satisfactory $5.00 jeep XJ
Bump stops Rear Xj bump stops Satisfactory $5.00 Jeep XJ
Battery hold down Battery hold down bracket w/o bolts Satisfactory $5.00 Jeep XJ,Mj
Dip stick tube 4.0L dipstick Tube with Dipstick Satisfactory $5.00 Jeep 4.0L
Belt tensioner 4.0L belt tensioner bracket Satisfactory $5.00 Jeep 4.0l
Engine mount bracket 4.0L Engine mount bracket Satisfactory $5.00 Jeep 4.0L
Alternator bracket 4.0L Inner and outter alternator brackets Satisfactory $5.00 Jeep 4.0L
Fan w/clutch 4.0L Mechanical fan w/clutch Satisfactory $5.00 Jeep 4.0L
water pump pulley 4.0L water pump pulley Satisfactory $5.00 Jeep 4.0L
Hatch shock Rear Hatch shock Satisfactory $5.00 Jeep 4.0L
EGR tube 4.0L Renix EGR tube Satisfactory $5.00 Jeep 4.0L
Battery hold down bar battery hold down bar Satisfactory $5.00 Jeep XJ,MJ
Injector O rings O rings New $7.00 Jeep 4.0L
valve cover gasket gasket New $10.00 Jeep 4.0L
Oil pan gasket gasket New $10.00 Jeep 4.0L
Distributor square plug Good $10.00 Jeep 4.0L
LH mirror exterior door mirror Good $10.00 Jeep XJ
TCU Transmission control unit AW4 Good $10.00 Jeep XJ
Cruze module cruze control module Good $10.00 Jeep XJ
Headlight switch headlight control switch Good $10.00 Jeep XJ
Shift indicator Aw4 shift indicator Good $10.00 Jeep XJ
A/C control panel Interior A/C control switch panel Good $10.00 Jeep XJ
Shifter boot Shifter boot Satisfactory $10.00 Jeep YJ
E-brake handle E-brake handle assembly Satisfactory $10.00 Jeep XJ
Seat belts Tan rear seatbelts Satisfactory $10.00 Jeep XJ
Throttle pedal Throttle pedal assembly Satisfactory $10.00 jeep XJ
Vac canister Vac canister bottle Satisfactory $10.00 Jeep XJ,MJ
Roll over valve Misc Roll over valve Satisfactory $10.00 Misc Misc
Ash tray maroon Ash tray Satisfactory $10.00 Jeep XJ,MJ
Pressure bottle Pressure tank and mount w/cap Satisfactory $10.00 Jeep XJ,MJ
Battery hold down Complete hold down bracket w/bolts Satisfactory $10.00 jeep XJ,MJ
Valve cover 4.0L valve cover Satisfactory $10.00 Jeep 4.0L
Air filter assem. 2.8L v6 air filter assembly Satisfactory $10.00 jeep 2.8L
Power steering pump 2.8L power steering pump and bracket Satisfactory $10.00 Jeep 2.8L
Power steering mount 4.0L power steering pump mount Satisfactory $10.00 Jeep 4.0L
Fan mount 4.0L fan blade mount Satisfactory $10.00 Jeep 4.0L
Pulley Ribbed pulley Satisfactory $10.00 jeep 4.0l
Pulley Smooth pulley Satisfactory $10.00 jeep 4.0L
Power steering pump Power steering pump w/o res Satisfactory $10.00 Jeep 4.0L
Axle brake line Rear D35/8.25 Axle brake line Satisfactory $10.00 Jeep D35/8.25
Throttle cable mount Mount to throttle body Renix Satisfactory $10.00 Jeep XJ,MJ
D30 Diff cover D30 diff cover Satisfactory $10.00 Jeep D30
Lock actuator Door lock actuator Satisfactory $10.00 Jeep XJ,MJ
Starter 4.0L starter Satisfactory $10.00 Jeep 4.0L
Motor plate 4.0L Motor plate Satisfactory $10.00 jeep 4.0L
Injectors HO 4.0L Satisfactory $15.00 Jeep 4.0L
Distributor 97+ 4.0L distributor Satisfactory $15.00 Jeep 4.0L
Wing windows LH wing windows stationary Satisfactory $15.00 Jeep XJ,MJ
Battery Tray RH Battery tray Satisfactory $15.00 Jeep XJ,MJ
Brake caliper D30 Brake caliper Satisfactory $15.00 Jeep Bendix
Speedo Gear 33,34,35 Satisfactory $20.00ea Jeep NP231/242/249
Fuel pump Bosch fuel pump Satisfactory $20.00 Jeep 4.0L
relay panel Under hood relay panel 97+ Satisfactory $20.00 Jeep 4.0L
Brake pedal ass. 92-96 brake pedal assembly Satisfactory $20.00 Jeep XJ
T/C shifter lever Transfer case shifter lever Satisfactory $20.00 Jeep CJ,TJ,XJ,MJ
Throttle body 4.0L Renix Throttle body Satisfactory $20.00 Jeep 4.0L
Battery Box After market Battery Box Satisfactory $20.00
Power steering pump 4.0L power steering pump w res Satisfactory $20.00 Jeep 4.0L
Window regulator Window regulator w scissor Satisfactory $20.00 Jeep XJ,MJ
Intake manifold Renix 4.0L intake manifold Satisfactory $20.00 Jeep 4.0L
intake manifold HO 4.0L intake manifold Satisfactory $20.00 Jeep 4.0L
Power steering pump 4.0L power steering pump w mount Satisfactory $25.00 Jeep 4.0L
Gas tank 88-96 Satisfactory Jeep XJ 4 $20.00
Door Drivers 84-96 4dr XJ,MJ Satisfactory Jeep XJ,MJ 1 $20.00
Door Pass rear, drivers rear Satisfactory Jeep XJ 1 $20.00
Door Pass front 84-96 XJ,MJ Satisfactory Jeep XJ 1 $20.00
Fender Driver 84-96 XJ,MJ Satisfactory Jeep XJ,Mj 1 $15.00
Driveshaft Rear D35 w slip yoke Satisfactory Jeep XJ 3 $15.00
Axle shaft D30 Vac disco w/stub Satisfactory Jeep XJ,MJ,YJ 1 $15.00
Receiver hitch 88-96 XJ Satisfactory Jeep XJ 1 $40.00
Exhaust manifold 2.8L Satisfactory Jeep XJ,MJ 2 $10.00
Exhaust manifold 40L renix Satisfactory Jeep XJ,MJ 3 $15.00
Fender Pass 85-96 XJ,MJ Satisfactory Jeep XJ,MJ 1 $15.00
Here's a stupid one, do you have the rear wiper arm spring for an 89 XJ? I got a new arm from the JY but it didn't have the spring, and my spring accidentally got tossed when I threw out the old broken wiper arm.
I'm sure I have a few arm's in my stack of wiper motors and assemblies. call me tomorrow afternoon.
Dave
480-600-9174
