Jeepin Jason
NAXJA Member #1100
- Lewisville, TX
Since I don't need them anymore (went back to stock bolt pattern) I'm selling my Dutman Motor Sports alloy XJ D44 shafts. You can get details on Dutchman's mfg at http://www.dutchmanms.com
These are custom-built alloy shafts with 5x5.5" bolt pattern, standard 30-spline. They are not dual drilled. The flanges are sized to fit stock XJ 10" drums and have screw-in studs. I don't know if they'd fit the smaller late model drums or not. The studs are too long for stock lugnuts to fit, so you'll need to use regular open nuts like the ones shown.
The shafts are 4 years old, but were used for only 2 of those years (the other two years they've been boxed up). They're complete with bearings, races, seals (should still be good), retainer plates, studs, etc. still on them and should be ready to be installed out of the box.
Here's the passenger side shaft on the right in this photo, being swapped out for some OEM shafts to go back to the stock bolt pattern.
I believe that the flange on the driver's side shaft is slightly bent, causing a little wheel wobble. I never really "felt" any vibration from this though, and it didn't seem to cause any abnormal tire wear.
They're located in Lewisville, TX (zip 75077) and I'd ship them UPS ground. Shipping weight is somewhere around 42-45 lbs. Total cost brand new was about $425, I'm selling them for $250 shipped anywhere in the Lower 48.
