SteveTC
- Hunlock Creek, PA
XJ Parts:
4.0 HO, 1991, ran good, complete less starter, $100
Auto trans from same, $85
Transfer Case, full time/part time, $70
Axles, will check gearing and models: $90/Pair
Many interior parts, had all power options, including seats, doors, windows, mirrors, $neg and cheap
Hurricane wheels/with stock but good 225-15 tires $80 set/4
Rear Hatch, white, small corner crack $20
Factory Sunroof $30
Doors, some dents and dings, $10 each
Universal grill guard, mid sized truck, black $30
Sell complete for parts until this weekend: $200 Firm
67 - 72 Blazer Parts:
Axles - Two Sets Look like D44F and 10 Bolt Rear, Flat Top Knuckles makes crossover easy, both with Warn Lockouts, One Set from Auto with 3:05 and one from 4 Speed, not sure of ratio Both have disc brake fronts and e-brake cables, 6-lug, $110/set
TH350 with NP205 Case, no shifter- $175.00
3" Lift Springs, not sure if re-arched or aftermarket $75
Complete Blazer rolling chassis, rusty, no eng, trans, case, shafts or title $75
Interior or Exterior parts as needed including consoles, etch.
Doors and Tailgate - $30 each
Removable Tops - $50 each
Other items:
Top tank from snap-on parts washer, sits on drum, no pump - $30
Craftsman Leaf ****er looks new - $15
ZJ Tank with pump - $30
Mobile home axles with wheels/tires and brakes (3) $30 each, $75 all
TH-350 with 4wd output shaft and Buick-Olds-Pontiac Bellhousing - $75
66-73 Jeepster rear liftgate hatch, surface rust and good glass - $40
Small Miltary Jeep Trailer, wooden box, no steel 3-1/2' x 4-1/2', no title, good lights, 2" ball hitch $100
Tow Bar - Bolt on flat front bumper, Reese, Sells for $215, will sell for $60
Tow Bar - Stainless Steel, heavy duty chassis/axle mount, homemade, needs ends made $40
e-mail [email protected]
Steve
Factory Sunroof $30
Other items:
Steve
