I tried purolator pureone's a couple of times, both on the 4.0 in the XJ and the 2.5L's in the TJ's.
In the XJ when I had the idiot light dash it took almost 30 seconds for the oil light to go out on a cold mornings start. I was used to the instant pressure from the Mopar OEM, K&N and the Mobil-1's I had been using. Went back to what I had been using. Once the gauge panel went in I tried it again and with the purolator it took just about 15 seconds for the pressure to build.
About 2 months ago I did it again, tried the Purolator pure one on the TJ's, they needed oil changes before we went to Cape Cod so I changed first my 97 with it's 2.5L 5 speed. Initally it went OK but on the next day while going up to a customers house to setup a wireless router my check gauges light came on, oil pressure at Idle was -0-,at 2K it was 20lbs, let off the gas and back to -0- again. Nursed it home and swapped in a K&N, pressure back and all was good, did the same thing on the YJ, back to a K&N for that one to. No more purolators for me, got one sitting on the shelf [shoulda took it back but forgot], it's a PL14670, anybody want it, come get it.
I stocked up at Advance Auto on Mobil-1's on sunday, they are running a special till the 30th....
