Rufio
- washington
just recently my jeep temp gets really high while sitting at idle, but when i start driving the temp drops to the norm. is this cause of a shot water pump or could it be beacause the thermostat any help?
that doesn't mean it is rotating with any force behind it, even with the clutch out the fan will spin , just not near as fast as it shouldRufio said:my fan is still rotating though....?
94_2wdcherokee said:I just had the same problem with my jeep and i changed out the Thermostat and it runs like a champ now! It was a real easy task.
reddragon72 said:I run no thermo in Houston, works alot better that way. My temps are easier to control when with it out, move just a tad and it is good to go. My radiator is starting to loose it tho, keeps killing water pumps with to much back pressure.
Rufio said:just recently my jeep temp gets really high while sitting at idle, but when i start driving the temp drops to the norm...
