NeXJ
- Los Angeles
thanasi85 - so I went to my local pep boys - and surprise surprise - the people working the parts counter had no idea what a 'failsafe thermostat' was - such is the nature of my local pep boys
- so I ended up getting a Stant Superstat... hope that will be the ticket.. thanks
If you want to check the water pump just do the following
1. See if water is coming out the weep hole.
2. Loosen the serpentine belt and remove it from the water pump pulley and give the pump pulley a wiggle and see if it had play in it and also give it a spin to make sure its spinning freely with no weird grinding noises.
But I would bet money its the T-Stat. Its real easy and quick to replace and should be the first place you start before looking at anything else. Go to AutoZone and get a failsafe thermostat.. its like $12 and you will never have to worry about it getting stuck closed.. I use them in all 5 of the XJ's we have with no issue.
