heshhash
- Proctor, MN
Thinking outside the box, when was last time you changed tranny fluid and the filter? Also for grins, check your fuel pressure.
Napa. I have the zj fan clutch. Can I fit a bigger rad?
friend of mine had over heat and turns out his ECU was fried and climate control system was communicating improperly. He bought a used ECU and all is good for the last 2 months. For what its worth my 2 pennies
I'll be adding a 2 ( or 3 i dont know whats better yet)row aluminum rad, and an additional trans cooler, possibly high flow water pump.
Recap: I can idle and 4x4 all day.(no ac)
High speed (above 50), uphill, or ac on, I overheat.
Fully flushed.
Oem parts replaced-hoses, tstat, rad, pump, exhaust mani, etc, etc.
In years past, working on several different XJs, I have tried several radiators and found the Mopar HD XJ radiator (52080104AC) works well, better than the 2 and 3-row CSFs or Napa's HD replacement.
1-1/2" 2-row.I'm curious, do you know the thickness of the core on the Mopar HD?
Cool! I'm anxious to hear the results!Alright, so I ordered a Mopar HD Radiator and I'll get it tomorrow, wish me luck
I'm officially calling it fixed!
Very stable temperatures in the 195-205 range, even while driving fast on warmer days on the hwy and up the mountain with the AC blasting =) I'm extremely happy about the cooling efficiency.
When I replaced with a Mopar HD my temps went into the normal/great range.
