Qban
- Long Beach, Ca
Finally made some progress.
So I put everything back together with the champion radiator (I'm stuck with it), two holes in the tstat, replaced all spring clamps with worm gear and still have the heater core bypassed.
So the machinist/mechanic at my company took a look. He found I still had air in the upper radiator hose. So he machined a pipe with a petcock and we put it in the highest point of the upper hose and we bled it that way.
I ran the jeep on the highway at about 65mph for over 10 min and had a consistent temperature of 205. =) yay!
Now I'm going to try taking the 605N from long beach to the 14 with the ac on at 65mph which is how I overheated the very first time.
Hopefully air is the only problem. The disappointing thing to me was that I spent the time and did my research which led me to believe that using a lisle spillfree funnel with the jeep on an angle while massaging the upper radiator hose was enough to burp the system and purge the air. I guess it's not enough sometimes =(
Here's a learning point for anyone. Shake the upper hose and listen for water splashing to see if you have air. I pinched the hose and thought it felt good but I was completely wrong.
