Overhead Console
A note for those interested in this part. The outside ambient temperature Sensor is common across all of the Chrysler products for these years. Based upon my installation of one of these, I recommend that the connector for the Sensor (located at the center of the header panel) be replaced as it will, most likely, be corroded beyond usability.
Also, if you have the RKE (remote keyless entry) be sure to transfer the module out of your current mini-overhead into this one so that the Fobs still work. Otherwise, it will be a trip to the Dealership for the RKE to be programmed.
