those part databases are just window dressing on a shared back-end, and does not mean that any of those sites have it. if a part is discontinued it's discontinued. maybe a dealer somewhere has one in stock but you have to go ask your parts desk to look that up
When looking for an XJ OHC bracket, keep in mind that the pre97 and 97+ brackets are the same. You might have better junkyard luck finding one in an older XJ.
The only difference is where the lettering "FWD" is stamped. Just spin the bracket around 180* so "FWD" faces rearward and the older bracket will grab the newer console in the correct spot.
I'm pretty sure the Dodge minivans with a center console (most of them) had the same mounting bracket, or at least the same console plastic molding as the 97+ XJs so it should be compatible sorta.
I love Cash for Clunkers. Found a ZJ with an overhead console that seemed to work. It only grabbed about 1/2 the tabs like JEEPZZ said, but it seems to be holding ok.
I guess I'll find out once I come off that first rock and everything slams down!
