OTK Steering Question
I did not like the hex aluminum steering that they sell with it, so I just bought the knuckle. The drag link was a JKS piece for WJ TREs and the tie rod I had custom made to use Currie HD TREs.
http://www.currieenterprises.com/cestore/product.aspx?id=1221
http://jksmfg.com/i-17393790-fab-drag-link.html
http://www.genright.com/ProductInfo.aspx?productid=STKTF44
I had already setup the OAB and ran into clearance issues running the tie rod OTK. This was simply because I did not plan for it. If you know this going in you can account for it and run OTK for your tie rod using Go-Ferit inserts.
http://www.goferitoffroad.com/products.htm
I ran JCR's OTK setup for a while.. Look at TnT customs track bar with the OTK bracket.. After moving one of the frame mount holes it drove like a dream. No bump steer or wobble.. Best combination IMO.
Before
After
