While the argument is fun to follow, we have lost sight of the point of the thread( Hint: it wasn't to argue. :looney: ) The fact is, if you never worry about rolling over, you don't need anything other then a conventional tech. lead-acid battery, and they're a butt-load cheaper then any of the alternatives. If your major concern is running a stereo, rolling over
probably isn't a
huge issue. If your major concern is powering a winch,..
slightly different story. When you're on the side of a trail, on your side, and the winch you want to use for recovery is attached to the battery under your hood, whether or not the acid has all spilled out of it becomes a legitimate concern. As long as the battery is upright, it really doesn't matter.
Milford: obviously, you don't like Optima batteries. Optimajim works for Optima. His posts sound like he sincerely believes they're a good product. Even if he doesn't have a high personal opinion of Optima batteries, he's not going to agree with you on a public forum.
Optimajim isn't going to debate the merits/drawbacks of different size/group batteries with you. It's a marketing thing. It's an "I like to stay employed" thing. Plus, he probably doesn't have the stats available to make an informed comparison, and probably isn't going to look them up/have someone run a test, and he's not going to talk out his a**. Personal aside: several people have pointed out that the batt you're comparing the Optima to is double the price. If I was willing to pay double the price that I paid for my XJ, I could have had a real nice Rubicon, that would out-perform my XJ in almost every off-road situation I can think of, short of spending that extra 12 grand on the XJ.
Optimajim has already answered you a couple times about why your battery failed. Here's the short version:
Short of tearing the failed component down, nobody can know for sure. It's all educated guesswork. He can't even make an educated guess, because he doesn't know how old the battery was, how it was used, etc. It could be a manufacturing flaw. It could be your charging system is over- or under-charging. 'Could be a piece of a plate broke off and shorted out a cell. It could be a mechanical failure of one of the terminal post connections inside the battery, or a connection between cells. He doesn't know. What I'm reading in his answers to you is that he doesn't know why your batt. failed, and he can't even guess at the cause.
In all honesty, you're making yourself look bad. The original thread question:
(i know it's bad form to refer to the original topic of a thread around here, but,..
My battery just died so I thought I might upgrade to an Optima,.. .., Does anyone have a good recommendation on these batteries or alternative battery manufacturers
He asked for opinions, and options.
You gave him your opinion: "Don't buy an Optima." :lecture:
You gave him your reasoning: "I had one, and it sucked" :wow:
You gave him an option: "Buy anything else but an Optima." :lecture:
Optimajim gave his take on your advice: "He's full of it." :doh:
EVERYTHING else you've said has made
you look worse. Several other posters have said they had Optimas fail, just like you did. Many(most) of them went out and got a second one(Yep, I'm one of them,.. "the definition of insanity: Repeating the same action again and again and expecting a different result." ) Interestingly,
most of us
have had a different result.
What I've gotten from this thread(including my own posts);
1: We like to argue.
2: AGM batteries are good technology,but expensive. Don't run them flat, or you likely will be buying another one.
3: We REALLY like to argue.
4: Sometimes sh*t breaks, we don't always know why.
5: We F***ing LOVE to M***ERF***ING argue.
