blondejoncherokee
- sacramento
so on top of the other carnage on my jeep from the con this last sunday(just welded the uca mount and gusseted it up tonight) the front diff has a bunch of metal in it. the gears look good, but the spacer behind the pinion is chewed up a bit. the ring gear bolts where all loose as well so i tightened them up. im going to run it for now and build another HP 30 on the side.
there are some very knowledgable guys here in the sierra chapter and id like some opinions on a good set of gears seeing as i always use the axles i find and never get new gears...
