Tackled the XJ again today. It is starting to become crunch time. My laundry list of sh!t is piling up so I have to bust my ass.
Since I went to Currie on Friday and got my axle shaft sear replaced, I figured I'd get it done first. Currie doesn't replace the seal but the whole damn bearing as well.
And Fishboy, it took me 20 minutes
Frankie hung with my the whole time I was out there.
Yanked the power steering pump out. I cannot beleive how much easier it is when that f#$%ing air box is not in the way!
And I worked on the PSC pump install. Look at the custom bent high pressure line. Looks like sh!t and with my luck it'll probably leak. I will call PSC tomorrow and figure out the optimum solution.
Hooked up the lines. I have the large diameter line coming out the back of the resevoir. Ended up cleanest that way
And the completed install except for the fluid and new serpentine belt.
The list for Rubicon is still long. I need to have it all done by Friday since I leave for NorCal on Sunday morning and have to pack on Saturday.
Things to do:
1. Rebuild LCA RE joints (killed them in 6 runs
2. Measure out and install new serpentine belt
3. Fluids. Fill powersteering and rear axle and top off the front diff and TC and check oil, tranny, and washer fluid.
4. Create brackets to mount new air compressor.
5. Wire relay and switches for air compressor
6. Grease CTMs
7. Wash jeep and get BOTW dust out of it
8. Clean air filter (from BOTW dust fest)
9. Install pitman arm
10. Pick up from Deaver and install leaf springs (and mount tires of course)
11. Install rear drive line.
I should get some of it done tomorrow and Tuesday. Hopefully it'll be drivable for the M&G on Wed and maybe I could get some help with the aircompressor (brackets and wiring). :angel:
