RCKCLMR
- Gadsden, AL.
Ok, my power antenna quit working one day and it was stuck in the down position. Earlier today, I removed the power antenna, took it apart and gave it a good cleaning. I lubed all the parts that needed it and put it back together. When I re-installed it (with ignition on and radio on), I had the antenna fully extended and everything was ok. As soon as I turned off the radio the antenna went down like it is supposed to. The only problems is, it will not come back up. No matter how I re-install it, it just won't go up. It will always go down with no problems but then it is stuck there. Any of you had this problem and if so, what did you do to fix it (besides new antenna)?
