DubaiXJ
- South Africa
I've run Old Man Emu in various configurations on XJ's and TJ's over the years and I'm a great fan. I often see posts on the forum asking for this or that about OME and all to often I see retailers making a hash of OME specifications. So, as a community service, I've put together a list of XJ OME data from my own notes, ARB and other (reliable) sources. I am fairly confident that the info is accurate but if I have made any errors or omissions please correct me.
Front Coil Springs:
OME Part # Description /Application Rates Free Height Est. Lift
OME930 Light / Standard Load 160 lbs/inch 18.7" 1.75"
OME930 Heavy Load 1 - 1.5"
OME 931 ZJ I6 140 lbs/inch 20.08" 1.5 - 2.5"
OME934 ZJ V8 180 lbs/inch 20.08" 2 - 3"
OMEJGF10 Trim Packer 10mm
Notes:
1) Left and Right springs typically have a 12mm Free Height difference to compensate for height or load variations between the left and right side of the vehicle, i.e. trimming.
2) Lift is only an estimation.
I'll post up the rear and shocks shortly.
Front Coil Springs:
Notes:
