I'm *trying* to wire in a switch so I can control when the XJ says in second gear or not.
Using this writeup http://www.bigoffroad.com/bigpages/bigtech/2ndgear.htm
here's what I've done:
Spliced into the yellow D16 wire and ran the new wire to my "12 volt supply" terminal in my rocker switch.
I then placed in a diode on C15, the violet wire, with the grey circle pointing towards the harness connector. Then behind the diode, I spliced in another wire and ran it to the "accs on" terminal for my rocker switch.
Then I spliced a ground for the switch into another ground wire.
While out on the "test drive", the tranny goes from 1st gear to 3rd. It doesn't to second, and it wont shift into overdrive either. This is with the switch off (unlighted), and the transmission in "D".
When I move the tranny into the 1 - 2 position, it'll start in 1st gear, but it wont shift out of first gear until I flip the switch, and then goes into second.
Does anybody have any ideas wtf could be wrong? I've already double checked which wires I spliced into.
