BIgDaddyChia
RRC Organizer
- Round Rock, TX
What do u think. Pic of it from the side.
Pics after i took it off
John B said:Cant tell by the pics, did you try checking for play while it was installed?
Might want to replace them anyway since it's already off the Jeep, then you have a baseline on your maintenance schedule.
BIgDaddyChia said:How can you not tell by the pics. I mean the first pic is of the driveshaft on the vehicle still and its touching metal to metal
kewlkatdady said:and don't work in sandles.....
ask me how I know.
DirtyMJ said:The joints are probably fine. That's 'mild contact' IMHO. It's when the yokes flatten that you have a problem. I'd just clearance it with a die grinder for until you get a SYE and high angle shaft.
hortonsinnm said:You can not really be serious?!?!?!? That is the worst thing to do to a drive shaft and u-joint. Now all you are doing with this idea is letting the u-joint go further than it should be causing undo wear and tear on them. Spend the little bit of money and get a drop bracket and some new u-joints and be done with it for good.
hortonsinnm said:The drop kit I have does not drop hang down more than stock. And the front shaft angles did not change.
hortonsinnm said:Doesn't Tom Woods make a u-joint that gives you ten more * of movement?
