Ok one more question
Wikkid98xj
NJ
Does anyone know off the top of their head the size nut that fits the carrier preload adjustment screw cap in the 8.25 I read some where 36mm can any one confirm?
That sounds right.
It is the same as your front axle unit bearing nut.
Pinion nut? I'm confused
Yes the big nut in tge center of the hub.
Luckily I had dana 30s laying all over the place to grab a set of nuts from
