Lawsoncl,
Yes there is full battery voltage at the sensor wire. Tested both on RUN/OFF and RUNNING. No difference full voltage at the sensor wire. At this point I am thinking that there is a bad connection to the gauge cluster, but not likely since ALL the other gauges are working but most likely is the gauge failed and suddenly.
