oil pan install trick?
athyonus
Gainesville, FL
I cant get my oil pan back on my 4.0, my front axle is in the way, i tried jacking the front end up untill the suspension was just hanging, but i still need like 1/2inch more clearance, whats the trick?
Disconnect the trabbar and shocks and let it drop some more would probably get you the extra clearance. If you took it off, you should be able to put it back in the same way also.
