Oil leak rear axle yoke
sserafin
Lakewood CO
I have oil coming from the yoke on an 8.25 rear axle...
I understand a few things can cause this such as the oil slinger or the pinion nut...
What has happened when I noticed the oil is the vibes have gotten bad... So, is the leaking yoke a cause of vibes, or could the vibes be causing the leak>?
Also how much of a concern is it to be leaking, its nut pouring out.
The vibes and leakage are likely caused by something moving in a way that it should not.
