What XJ wheels are lug centric? I thought they were all hub centric, even if the hubs are too shallow to be any use in hanging a wheel in the dark.Its not cosmetic for me, the 5 spoke's, are a sliiiight PITA to work with... hard to realign them for re-assembly, especially in the dark....
Go work on a rig with steelies, or other wheels with a thin wheel mounting surface, theyre much easier to work with... this wouldnt matter on a hub centric wheel as much, but since theyre lug centric, i like to be able to see the wheel shift on the lugs as you cinch that first lug down tight.
PERSONAL preferance.
Is there a list of the different Jepp Wheels? I always see people naming the wheels they are talking about. I know them all by looking at them but I never know the wheel by name
Factory XJ wheels fit snugly on the hub. (At least the ones I've had). If you keep one long enough in the rust belt you'll encounter the frustration of having to beat a frozen one off the hub.AFAIK all XJ wheels are lug centric. They've got the conical lug nuts for a reason I thought :dunno: My Cragars I got for the XJ (now on the MJ) are definitely lug centric, since the centerbores are significantly larger than an XJ hub.
I ran ZJ Canyon rims on my MJ (till I lifted it, the tires I got are 16s and don't fit them) for a long time simply because I liked the way they looked.
I can add that all four steel types I've had were also.Aluminum XJ (and TJ/KJ) wheels are definitely hubcentric.
That's interesting. All mine have gone on pretty snug, and it's rare after a few months not to have to slam them off with a series of backward kicks or a very very big hammer. I would have considered that at least somewhat hub-centric, but I don't want to start splitting technical hairs.Ive never seen an xj wheel go on snug to the hub.... so with my understanding of the hub vs lug centric theory, that'd make them lug centric?
5 spoke alloys, 11(i beleive its 11) spokes, steelies, never seen LESS THAN 1/16th space between the middle of the axle shafts, and the wheel.
Someone settle this...
I have found that cranking the lugs off about 4 turns, lowering the jeep back onto the ground (full weight), and whacking it really, really hard with a 3lb sledge (protect the wheel with some plywood if you care about it...) will usually take them off, even when they are really seized on there. Normally a good solid kick will take mine off, but I did some work on a ZJ last year that required this trick. Even smacking it as hard as I could with the sledge while it was on the lift didn't budge it, nor did neutral drops with the lugs loosened.That's interesting. All mine have gone on pretty snug, and it's rare after a few months not to have to slam them off with a series of backward kicks or a very very big hammer. I would have considered that at least somewhat hub-centric, but I don't want to start splitting technical hairs.
XJ's are lug centric, if they were hub centric it would be critical to maintian a good fit between the hub and rim. There are special plastic adapters used to obtain this tight clearance when using aftermarket wheels.
I have roughly 1/4" of clearance between the hub and the black D steelies I am running now
